{"name":"Sektion Oldies","description":"Sveriges snabbaste motorklubb","url":"https:\/\/dev.clubcorvette.se\/oldies","home":"https:\/\/dev.clubcorvette.se\/oldies","gmt_offset":1,"timezone_string":"Europe\/Stockholm","page_for_posts":0,"page_on_front":9,"show_on_front":"page","namespaces":["oembed\/1.0","events-manager\/v1","members\/v1","tnp","oauth\/v1","events-manager-pro\/v1","gravityforms\/v2","newsletter","wp-smush\/v1","hub-connector\/v1","clubcorvette\/v1","stripe\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/dev.clubcorvette.se\/oldies\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Resursens URL f\u00f6r h\u00e4mtning av oEmbed-uppgifter.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Resursens URL f\u00f6r h\u00e4mtning av oEmbed-uppgifter.","type":"string","format":"uri","required":true},"format":{"description":"Format som anv\u00e4nds f\u00f6r oEmbed.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Maximal bredd hos embed-ramen i pixlar.","type":"integer","default":600,"required":false},"maxheight":{"description":"Maximal h\u00f6jd hos embed-ramen i pixlar.","type":"integer","required":false},"discover":{"description":"Huruvida en beg\u00e4ran f\u00f6r efterfr\u00e5gan om oEmbed ska utf\u00f6ras f\u00f6r tj\u00e4nster som inte \u00e4r godk\u00e4nda.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/oembed\/1.0\/proxy"}]}},"\/events-manager\/v1":{"namespace":"events-manager\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"events-manager\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1"}]}},"\/events-manager\/v1\/uploads":{"namespace":"events-manager\/v1","methods":["POST","DELETE","GET"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["DELETE"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/uploads"}]}},"\/events-manager\/v1\/blocks\/event\/validate":{"namespace":"events-manager\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"type":"integer","default":0,"required":false},"post_type":{"type":"string","required":true},"form_data":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/blocks\/event\/validate"}]}},"\/events-manager\/v1\/events":{"namespace":"events-manager\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/events"}]}},"\/events-manager\/v1\/events\/(?P<id>[\\d:]+)\/availability":{"namespace":"events-manager\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/events-manager\/v1\/events\/(?P<id>[\\d:]+)\/tickets":{"namespace":"events-manager\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}]},"\/events-manager\/v1\/events\/(?P<id>[\\d:]+)":{"namespace":"events-manager\/v1","methods":["GET","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/events-manager\/v1\/tickets\/(?P<id>\\d+)":{"namespace":"events-manager\/v1","methods":["GET","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/events-manager\/v1\/locations":{"namespace":"events-manager\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/locations"}]}},"\/events-manager\/v1\/locations\/countries":{"namespace":"events-manager\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/locations\/countries"}]}},"\/events-manager\/v1\/locations\/regions":{"namespace":"events-manager\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/locations\/regions"}]}},"\/events-manager\/v1\/locations\/states":{"namespace":"events-manager\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/locations\/states"}]}},"\/events-manager\/v1\/locations\/towns":{"namespace":"events-manager\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/locations\/towns"}]}},"\/events-manager\/v1\/locations\/(?P<id>\\d+)":{"namespace":"events-manager\/v1","methods":["GET","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/events-manager\/v1\/bookings":{"namespace":"events-manager\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/bookings"}]}},"\/events-manager\/v1\/bookings\/(?P<id>[\\w-]+)":{"namespace":"events-manager\/v1","methods":["GET","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/events-manager\/v1\/bookings\/(?P<id>[\\w-]+)\/status":{"namespace":"events-manager\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/events-manager\/v1\/media":{"namespace":"events-manager\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/media"}]}},"\/events-manager\/v1\/categories":{"namespace":"events-manager\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/categories"}]}},"\/events-manager\/v1\/categories\/(?P<id>\\d+)":{"namespace":"events-manager\/v1","methods":["GET","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/events-manager\/v1\/tags":{"namespace":"events-manager\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/tags"}]}},"\/events-manager\/v1\/tags\/(?P<id>\\d+)":{"namespace":"events-manager\/v1","methods":["GET","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/events-manager\/v1\/app\/notifications\/types":{"namespace":"events-manager\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/app\/notifications\/types"}]}},"\/events-manager\/v1\/app\/devices":{"namespace":"events-manager\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/app\/devices"}]}},"\/members\/v1":{"namespace":"members\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"members\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/members\/v1"}]}},"\/members\/v1\/content-permissions\/(?P<id>\\d+)":{"namespace":"members\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"integer","required":true},"roles":{"type":"array","items":{"type":"string"},"required":true},"message":{"type":"string","required":true}}}]},"\/members\/v1\/ai":{"namespace":"members\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"read_only":{"type":"boolean","required":false},"disabled":{"type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/members\/v1\/ai"}]}},"\/members\/v1\/ai\/log":{"namespace":"members\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"type":"integer","minimum":1,"default":1,"required":false},"changes_only":{"type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/members\/v1\/ai\/log"}]}},"\/members\/v1\/ai\/app-password":{"namespace":"members\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/members\/v1\/ai\/app-password"}]}},"\/members\/v1\/ai\/adapter":{"namespace":"members\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/members\/v1\/ai\/adapter"}]}},"\/tnp":{"namespace":"tnp","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"tnp","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/tnp"}]}},"\/tnp\/o\/(?P<email_id>[\\d]+)\/(?P<user_id>-?[\\d]+)\/(?P<signature>.+).gif":{"namespace":"tnp","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/tnp\/l\/(?P<email_id>[\\d]+)\/(?P<user_id>-?[\\d]+)\/(?P<url>.+)\/(?P<signature>.+)":{"namespace":"tnp","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/oauth\/v1":{"namespace":"oauth\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oauth\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/oauth\/v1"}]}},"\/oauth\/v1\/token":{"namespace":"oauth\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/oauth\/v1\/token"}]}},"\/oauth\/v1\/revoke":{"namespace":"oauth\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/oauth\/v1\/revoke"}]}},"\/oauth\/v1\/register":{"namespace":"oauth\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/oauth\/v1\/register"}]}},"\/oauth\/v1\/metadata":{"namespace":"oauth\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/oauth\/v1\/metadata"}]}},"\/oauth\/v1\/jwks":{"namespace":"oauth\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/oauth\/v1\/jwks"}]}},"\/events-manager-pro\/v1":{"namespace":"events-manager-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"events-manager-pro\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager-pro\/v1"}]}},"\/events-manager-pro\/v1\/bookings\/forms\/(?P<type>booking|attendee)":{"namespace":"events-manager-pro\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","enum":["booking","attendee"],"description":"Form type.","required":true}}},{"methods":["POST"],"args":{"type":{"type":"string","enum":["booking","attendee"],"description":"Form type.","required":true},"name":{"type":"string","description":"Form name.","required":false},"fields":{"type":"object","description":"Form fields keyed by field ID.","required":false},"form":{"type":"object","description":"Alias for fields.","required":false}}}]},"\/events-manager-pro\/v1\/bookings\/forms\/(?P<type>booking|attendee)\/(?P<id>\\d+)":{"namespace":"events-manager-pro\/v1","methods":["GET","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","enum":["booking","attendee"],"description":"Form type.","required":true},"id":{"type":"integer","description":"Form ID.","required":true}}},{"methods":["PATCH"],"args":{"type":{"type":"string","enum":["booking","attendee"],"description":"Form type.","required":true},"id":{"type":"integer","description":"Form ID.","required":true},"name":{"type":"string","description":"Form name.","required":false},"fields":{"type":"object","description":"Form fields keyed by field ID.","required":false},"form":{"type":"object","description":"Alias for fields.","required":false}}},{"methods":["DELETE"],"args":{"type":{"type":"string","enum":["booking","attendee"],"description":"Form type.","required":true},"id":{"type":"integer","description":"Form ID.","required":true}}}]},"\/events-manager-pro\/v1\/bookings\/forms\/(?P<type>booking|attendee)\/(?P<id>\\d+)\/default":{"namespace":"events-manager-pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["booking","attendee"],"description":"Form type.","required":true},"id":{"type":"integer","description":"Form ID.","required":true}}}]},"\/events-manager-pro\/v1\/bookings\/forms\/(?P<type>booking|attendee)\/(?P<id>\\d+)\/duplicate":{"namespace":"events-manager-pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["booking","attendee"],"description":"Form type.","required":true},"id":{"type":"integer","description":"Form ID.","required":true}}}]},"\/events-manager\/v1\/attendance":{"namespace":"events-manager\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager\/v1\/attendance"}]}},"\/events-manager-pro\/v1\/coupons":{"namespace":"events-manager-pro\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"type":"integer","default":1,"minimum":1,"description":"Page number.","required":false},"per_page":{"type":"integer","default":20,"minimum":1,"maximum":100,"description":"Number of items to return per page.","required":false},"search":{"type":"string","description":"Search term.","required":false}}},{"methods":["POST"],"args":{"code":{"type":"string","description":"Coupon code.","required":false},"name":{"type":"string","description":"Coupon name.","required":false},"description":{"type":"string","description":"Coupon description.","required":false},"start":{"type":"string","description":"Coupon start date.","required":false},"end":{"type":"string","description":"Coupon end date.","required":false},"max":{"type":"integer","description":"Maximum number of uses.","required":false},"type":{"type":"string","enum":["%","#"],"description":"Discount type.","required":false},"tax":{"type":"string","enum":["pre","post"],"description":"Whether discount applies before or after tax.","required":false},"discount":{"type":"number","description":"Discount amount.","required":false},"eventwide":{"type":"boolean","description":"Whether this coupon applies to all events owned by the coupon owner.","required":false},"sitewide":{"type":"boolean","description":"Whether this coupon applies to all site events.","required":false},"private":{"type":"boolean","description":"Whether this coupon is restricted to logged-in users.","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager-pro\/v1\/coupons"}]}},"\/events-manager-pro\/v1\/coupons\/(?P<id>\\d+)":{"namespace":"events-manager-pro\/v1","methods":["GET","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"Coupon ID.","required":true}}},{"methods":["PATCH"],"args":{"id":{"type":"integer","description":"Coupon ID.","required":true},"code":{"type":"string","description":"Coupon code.","required":false},"name":{"type":"string","description":"Coupon name.","required":false},"description":{"type":"string","description":"Coupon description.","required":false},"start":{"type":"string","description":"Coupon start date.","required":false},"end":{"type":"string","description":"Coupon end date.","required":false},"max":{"type":"integer","description":"Maximum number of uses.","required":false},"type":{"type":"string","enum":["%","#"],"description":"Discount type.","required":false},"tax":{"type":"string","enum":["pre","post"],"description":"Whether discount applies before or after tax.","required":false},"discount":{"type":"number","description":"Discount amount.","required":false},"eventwide":{"type":"boolean","description":"Whether this coupon applies to all events owned by the coupon owner.","required":false},"sitewide":{"type":"boolean","description":"Whether this coupon applies to all site events.","required":false},"private":{"type":"boolean","description":"Whether this coupon is restricted to logged-in users.","required":false}}},{"methods":["DELETE"],"args":{"id":{"type":"integer","description":"Coupon ID.","required":true}}}]},"\/events-manager-pro\/v1\/coupons\/(?P<id>\\d+)\/validate":{"namespace":"events-manager-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"Coupon ID.","required":true},"event_id":{"type":"string","description":"Event ID or event ID with timeslot suffix.","required":false},"total":{"type":"number","description":"Optional booking total used to quote the discount.","required":false}}}]},"\/events-manager-pro\/v1\/events\/(?P<id>[\\d:]+)\/coupons":{"namespace":"events-manager-pro\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/events-manager-pro\/v1\/events\/(?P<id>[\\d:]+)\/coupons\/(?P<coupon_id>\\d+)":{"namespace":"events-manager-pro\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}]},"\/events-manager-pro\/v1\/bookings\/transactions":{"namespace":"events-manager-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"type":"integer","default":1,"minimum":1,"description":"Page number.","required":false},"per_page":{"type":"integer","default":20,"minimum":1,"maximum":100,"description":"Number of items to return per page.","required":false},"search":{"type":"string","description":"Search term.","required":false},"gateway":{"type":"string","description":"Gateway slug filter.","required":false},"booking_id":{"type":"integer","description":"Booking ID filter.","required":false},"status":{"type":"string","description":"Transaction status filter.","required":false},"orderby":{"type":"string","enum":["transaction_id","transaction_timestamp","transaction_total_amount","transaction_gateway","transaction_status"],"description":"Sort field.","required":false},"order":{"type":"string","enum":["ASC","DESC"],"default":"DESC","description":"Sort direction.","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/events-manager-pro\/v1\/bookings\/transactions"}]}},"\/events-manager-pro\/v1\/bookings\/transactions\/(?P<id>\\d+)":{"namespace":"events-manager-pro\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"Transaction ID.","required":true}}},{"methods":["DELETE"],"args":{"id":{"type":"integer","description":"Transaction ID.","required":true}}}]},"\/events-manager-pro\/v1\/bookings\/(?P<id>\\d+)\/transactions":{"namespace":"events-manager-pro\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"Booking ID.","required":true},"page":{"type":"integer","default":1,"minimum":1,"description":"Page number.","required":false},"per_page":{"type":"integer","default":20,"minimum":1,"maximum":100,"description":"Number of items to return per page.","required":false},"search":{"type":"string","description":"Search term.","required":false},"gateway":{"type":"string","description":"Gateway slug filter.","required":false},"booking_id":{"type":"integer","description":"Booking ID filter.","required":false},"status":{"type":"string","description":"Transaction status filter.","required":false},"orderby":{"type":"string","enum":["transaction_id","transaction_timestamp","transaction_total_amount","transaction_gateway","transaction_status"],"description":"Sort field.","required":false},"order":{"type":"string","enum":["ASC","DESC"],"default":"DESC","description":"Sort direction.","required":false}}},{"methods":["POST"],"args":{"id":{"type":"integer","description":"Booking ID.","required":true},"amount":{"type":"number","description":"Payment amount received, in the site currency. Use a negative number to credit.","required":true},"type":{"type":"string","default":"cash","description":"Payment method, e.g. cash, card, cheque, transfer.","required":false},"note":{"type":"string","description":"Optional note stored against the transaction.","required":false},"approve":{"type":"boolean","default":true,"description":"Approve the booking automatically once it is fully paid.","required":false}}}]},"\/events-manager-pro\/v1\/bookings\/attendance\/(?P<id>[\\w-]+)":{"namespace":"events-manager-pro\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"string","description":"Ticket booking ID or UUID.","required":true}}},{"methods":["POST"],"args":{"id":{"type":"string","description":"Ticket booking ID or UUID.","required":true},"action":{"type":"string","enum":["checkin","checkout"],"description":"Attendance action to perform.","required":true}}}]},"\/events-manager-pro\/v1\/bookings\/rsvp\/(?P<id>[\\w-]+)":{"namespace":"events-manager-pro\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"string","description":"Booking ID or UUID.","required":true}}},{"methods":["POST"],"args":{"id":{"type":"string","description":"Booking ID or UUID.","required":true},"status":{"type":["integer","null"],"enum":[0,1,2,null],"description":"RSVP status: 1 confirmed, 0 declined, 2 maybe, or null for no response.","required":false}}}]},"\/gravityforms\/v2":{"namespace":"gravityforms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"gravityforms\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/gravityforms\/v2"}]}},"\/gravityforms\/v2\/tests\/mock-data":{"namespace":"gravityforms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/gravityforms\/v2\/tests\/mock-data"}]}},"\/newsletter":{"namespace":"newsletter","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"newsletter","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/newsletter"}]}},"\/newsletter\/manager":{"namespace":"newsletter","methods":["POST","GET"],"endpoints":[{"methods":["POST","GET"],"args":{"k":{"required":true},"what":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/newsletter\/manager"}]}},"\/wp-smush\/v1":{"namespace":"wp-smush\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-smush\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-smush\/v1"}]}},"\/wp-smush\/v1\/preset_configs":{"namespace":"wp-smush\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-smush\/v1\/preset_configs"}]}},"\/hub-connector\/v1":{"namespace":"hub-connector\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"hub-connector\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/hub-connector\/v1"}]}},"\/hub-connector\/v1\/sync":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"force":{"description":"Should do a force sync.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/hub-connector\/v1\/sync"}]}},"\/hub-connector\/v1\/logout":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/hub-connector\/v1\/logout"}]}},"\/clubcorvette\/v1":{"namespace":"clubcorvette\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"clubcorvette\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/clubcorvette\/v1"}]}},"\/clubcorvette\/v1\/user":{"namespace":"clubcorvette\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/clubcorvette\/v1\/user"}]}},"\/stripe\/v1":{"namespace":"stripe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"stripe\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/stripe\/v1"}]}},"\/stripe\/v1\/webhook":{"namespace":"stripe\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/stripe\/v1\/webhook"}]}},"\/clubcorvette\/v1\/lostpassword":{"namespace":"clubcorvette\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"email":{"type":"string","format":"email","required":true}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/clubcorvette\/v1\/lostpassword"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som publicerats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som tilldelats vissa f\u00f6rfattare.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Se till att resultatet inte inneh\u00e5ller inl\u00e4gg som tillh\u00f6r vissa f\u00f6rfattare.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Begr\u00e4nsa svaret till inl\u00e4gg som publicerats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hur s\u00f6kbegrepp ska tolkas.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter inl\u00e4ggsattribut.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array av kolumnnamn som ska s\u00f6kas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg med en eller flera specifika sluggar.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4r tilldelade en eller flera statusar.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false},"tax_relation":{"description":"Begr\u00e4nsa resultatet baserat p\u00e5 relationer mellan flera taxonomier.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Begr\u00e4nsa resultatet till objekt som tilldelats en viss term i taxonomin categories.","type":["object","array"],"oneOf":[{"title":"Lista \u00f6ver term-ID:n","description":"Matcha termer med uppr\u00e4knade ID:n.","type":"array","items":{"type":"integer"}},{"title":"S\u00f6kning i taxonomi \u00f6ver term-ID","description":"Genomf\u00f6r en avancerad terms\u00f6kning.","type":"object","properties":{"terms":{"description":"Term-ID:n.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Om underordnade termer ska inkluderas i termerna som begr\u00e4nsar resultatet.","type":"boolean","default":false},"operator":{"description":"Om inl\u00e4gg m\u00e5ste ha tilldelats alla eller n\u00e5gon av de angivna termerna.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Begr\u00e4nsa resultatet till alla objekt utom de som tilldelats en viss term i taxonomin categories.","type":["object","array"],"oneOf":[{"title":"Lista \u00f6ver term-ID:n","description":"Matcha termer med uppr\u00e4knade ID:n.","type":"array","items":{"type":"integer"}},{"title":"S\u00f6kning i taxonomi \u00f6ver term-ID","description":"Genomf\u00f6r en avancerad terms\u00f6kning.","type":"object","properties":{"terms":{"description":"Term-ID:n.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Om underordnade termer ska inkluderas i termerna som begr\u00e4nsar resultatet.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Begr\u00e4nsa resultatet till objekt som tilldelats en viss term i taxonomin tags.","type":["object","array"],"oneOf":[{"title":"Lista \u00f6ver term-ID:n","description":"Matcha termer med uppr\u00e4knade ID:n.","type":"array","items":{"type":"integer"}},{"title":"S\u00f6kning i taxonomi \u00f6ver term-ID","description":"Genomf\u00f6r en avancerad terms\u00f6kning.","type":"object","properties":{"terms":{"description":"Term-ID:n.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Om inl\u00e4gg m\u00e5ste ha tilldelats alla eller n\u00e5gon av de angivna termerna.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Begr\u00e4nsa resultatet till alla objekt utom de som tilldelats en viss term i taxonomin tags.","type":["object","array"],"oneOf":[{"title":"Lista \u00f6ver term-ID:n","description":"Matcha termer med uppr\u00e4knade ID:n.","type":"array","items":{"type":"integer"}},{"title":"S\u00f6kning i taxonomi \u00f6ver term-ID","description":"Genomf\u00f6r en avancerad terms\u00f6kning.","type":"object","properties":{"terms":{"description":"Term-ID:n.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4r klistrade.","type":"boolean","required":false},"ignore_sticky":{"description":"Om man ska ignorera klistrade inl\u00e4gg eller ej.","type":"boolean","default":true,"required":false},"format":{"description":"Begr\u00e4nsa resultatet till objekt tilldelade med ett eller flera givna format.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-inneh\u00e5ll f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av inl\u00e4gget.","type":"integer","required":false},"excerpt":{"description":"Utdraget f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Utdrag f\u00f6r inl\u00e4gget, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-utdrag f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Om utdraget \u00e4r l\u00f6senordsskyddat.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID f\u00f6r inl\u00e4ggets utvalda media.","type":"integer","required":false},"comment_status":{"description":"Om kommentering f\u00f6r inl\u00e4gget \u00e4r \u00f6ppen eller inte.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Om inl\u00e4gget kan pingas eller inte.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Inl\u00e4ggets format.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Om inl\u00e4gget ska behandlas som klistrat eller inte.","type":"boolean","required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false},"categories":{"description":"Termer tilldelade till inl\u00e4gget i taxonomi category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Termer tilldelade till inl\u00e4gget i taxonomi post_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u00c5sidos\u00e4tt standardl\u00e4ngden f\u00f6r utdrag.","type":"integer","required":false},"password":{"description":"L\u00f6senordet f\u00f6r inl\u00e4gget om det \u00e4r l\u00f6senordsskyddat.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-inneh\u00e5ll f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av inl\u00e4gget.","type":"integer","required":false},"excerpt":{"description":"Utdraget f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Utdrag f\u00f6r inl\u00e4gget, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-utdrag f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Om utdraget \u00e4r l\u00f6senordsskyddat.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID f\u00f6r inl\u00e4ggets utvalda media.","type":"integer","required":false},"comment_status":{"description":"Om kommentering f\u00f6r inl\u00e4gget \u00e4r \u00f6ppen eller inte.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Om inl\u00e4gget kan pingas eller inte.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Inl\u00e4ggets format.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Om inl\u00e4gget ska behandlas som klistrat eller inte.","type":"boolean","required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false},"categories":{"description":"Termer tilldelade till inl\u00e4gget i taxonomi category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Termer tilldelade till inl\u00e4gget i taxonomi post_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Om papperskorgen ska hoppas \u00f6ver och borttagning ske direkt i st\u00e4llet.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samlingen efter objektattribut.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true eftersom versioner inte kan hanteras via papperskorgen.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-inneh\u00e5ll f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av inl\u00e4gget.","type":"integer","required":false},"excerpt":{"description":"Utdraget f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Utdrag f\u00f6r inl\u00e4gget, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-utdrag f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Om utdraget \u00e4r l\u00f6senordsskyddat.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID f\u00f6r inl\u00e4ggets utvalda media.","type":"integer","required":false},"comment_status":{"description":"Om kommentering f\u00f6r inl\u00e4gget \u00e4r \u00f6ppen eller inte.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Om inl\u00e4gget kan pingas eller inte.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Inl\u00e4ggets format.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Om inl\u00e4gget ska behandlas som klistrat eller inte.","type":"boolean","required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false},"categories":{"description":"Termer tilldelade till inl\u00e4gget i taxonomi category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Termer tilldelade till inl\u00e4gget i taxonomi post_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Autosparade versionens ID.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som publicerats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som tilldelats vissa f\u00f6rfattare.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Se till att resultatet inte inneh\u00e5ller inl\u00e4gg som tillh\u00f6r vissa f\u00f6rfattare.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Begr\u00e4nsa svaret till inl\u00e4gg som publicerats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg med ett visst v\u00e4rde f\u00f6r menu_order.","type":"integer","required":false},"search_semantics":{"description":"Hur s\u00f6kbegrepp ska tolkas.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter inl\u00e4ggsattribut.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Begr\u00e4nsa resultatet till objekt som h\u00f6r till specifika \u00f6verordnade ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Begr\u00e4nsa resultatet till alla objekt f\u00f6rutom de med ett visst \u00f6verordnat ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array av kolumnnamn som ska s\u00f6kas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg med en eller flera specifika sluggar.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4r tilldelade en eller flera statusar.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"parent":{"description":"ID f\u00f6r inl\u00e4ggets \u00f6verordnade objekt.","type":"integer","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-inneh\u00e5ll f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av inl\u00e4gget.","type":"integer","required":false},"excerpt":{"description":"Utdraget f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Utdrag f\u00f6r inl\u00e4gget, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-utdrag f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Om utdraget \u00e4r l\u00f6senordsskyddat.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID f\u00f6r inl\u00e4ggets utvalda media.","type":"integer","required":false},"comment_status":{"description":"Om kommentering f\u00f6r inl\u00e4gget \u00e4r \u00f6ppen eller inte.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Om inl\u00e4gget kan pingas eller inte.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Inl\u00e4ggets sorteringsordning i relation till andra inl\u00e4gg.","type":"integer","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u00c5sidos\u00e4tt standardl\u00e4ngden f\u00f6r utdrag.","type":"integer","required":false},"password":{"description":"L\u00f6senordet f\u00f6r inl\u00e4gget om det \u00e4r l\u00f6senordsskyddat.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"parent":{"description":"ID f\u00f6r inl\u00e4ggets \u00f6verordnade objekt.","type":"integer","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-inneh\u00e5ll f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av inl\u00e4gget.","type":"integer","required":false},"excerpt":{"description":"Utdraget f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Utdrag f\u00f6r inl\u00e4gget, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-utdrag f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Om utdraget \u00e4r l\u00f6senordsskyddat.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID f\u00f6r inl\u00e4ggets utvalda media.","type":"integer","required":false},"comment_status":{"description":"Om kommentering f\u00f6r inl\u00e4gget \u00e4r \u00f6ppen eller inte.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Om inl\u00e4gget kan pingas eller inte.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Inl\u00e4ggets sorteringsordning i relation till andra inl\u00e4gg.","type":"integer","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Om papperskorgen ska hoppas \u00f6ver och borttagning ske direkt i st\u00e4llet.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samlingen efter objektattribut.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true eftersom versioner inte kan hanteras via papperskorgen.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID f\u00f6r inl\u00e4ggets \u00f6verordnade objekt.","type":"integer","required":false},"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-inneh\u00e5ll f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av inl\u00e4gget.","type":"integer","required":false},"excerpt":{"description":"Utdraget f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Utdrag f\u00f6r inl\u00e4gget, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-utdrag f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Om utdraget \u00e4r l\u00f6senordsskyddat.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID f\u00f6r inl\u00e4ggets utvalda media.","type":"integer","required":false},"comment_status":{"description":"Om kommentering f\u00f6r inl\u00e4gget \u00e4r \u00f6ppen eller inte.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Om inl\u00e4gget kan pingas eller inte.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Inl\u00e4ggets sorteringsordning i relation till andra inl\u00e4gg.","type":"integer","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Autosparade versionens ID.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som publicerats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som tilldelats vissa f\u00f6rfattare.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Se till att resultatet inte inneh\u00e5ller inl\u00e4gg som tillh\u00f6r vissa f\u00f6rfattare.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Begr\u00e4nsa svaret till inl\u00e4gg som publicerats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hur s\u00f6kbegrepp ska tolkas.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter inl\u00e4ggsattribut.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Begr\u00e4nsa resultatet till objekt som h\u00f6r till specifika \u00f6verordnade ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Begr\u00e4nsa resultatet till alla objekt f\u00f6rutom de med ett visst \u00f6verordnat ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array av kolumnnamn som ska s\u00f6kas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg med en eller flera specifika sluggar.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4r tilldelade en eller flera statusar.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Begr\u00e4nsa resultatupps\u00e4ttningen till bilagor av viss eller vissa medietyper.","type":"array","items":{"type":"string","enum":["image","video","audio","application"]},"required":false},"mime_type":{"default":null,"description":"Begr\u00e4nsa resultatupps\u00e4ttningen till bilagor av viss eller vissa MIME-typer.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av inl\u00e4gget.","type":"integer","required":false},"featured_media":{"description":"ID f\u00f6r inl\u00e4ggets utvalda media.","type":"integer","required":false},"comment_status":{"description":"Om kommentering f\u00f6r inl\u00e4gget \u00e4r \u00f6ppen eller inte.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Om inl\u00e4gget kan pingas eller inte.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false},"smush":{"description":"Smush-data.","type":"string","required":false},"alt_text":{"description":"Alternativ text att visa n\u00e4r bilagan inte visas.","type":"string","required":false},"caption":{"description":"Bilagans bildtext.","type":"object","properties":{"raw":{"description":"Bildtext f\u00f6r bilagan som den ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-bildtext f\u00f6r bilagan, omvandlad f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Bilagans beskrivning.","type":"object","properties":{"raw":{"description":"Beskrivning av bilagan som den ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-beskrivning av bilagan, omvandlad f\u00f6r visning.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"ID f\u00f6r bilagans associerade inl\u00e4gg.","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"Om understorlekar ska genereras f\u00f6r bilder.","required":false},"convert_format":{"type":"boolean","default":true,"description":"Om bildformat ska konverteras.","required":false},"url":{"type":"string","format":"uri","description":"URL till en extern bild som ska sidladdas in i mediebiblioteket, ist\u00e4llet f\u00f6r att ladda upp en fil.","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av inl\u00e4gget.","type":"integer","required":false},"featured_media":{"description":"ID f\u00f6r inl\u00e4ggets utvalda media.","type":"integer","required":false},"comment_status":{"description":"Om kommentering f\u00f6r inl\u00e4gget \u00e4r \u00f6ppen eller inte.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Om inl\u00e4gget kan pingas eller inte.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false},"smush":{"description":"Smush-data.","type":"string","required":false},"alt_text":{"description":"Alternativ text att visa n\u00e4r bilagan inte visas.","type":"string","required":false},"caption":{"description":"Bilagans bildtext.","type":"object","properties":{"raw":{"description":"Bildtext f\u00f6r bilagan som den ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-bildtext f\u00f6r bilagan, omvandlad f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Bilagans beskrivning.","type":"object","properties":{"raw":{"description":"Beskrivning av bilagan som den ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-beskrivning av bilagan, omvandlad f\u00f6r visning.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"ID f\u00f6r bilagans associerade inl\u00e4gg.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Om papperskorgen ska hoppas \u00f6ver och borttagning ske direkt i st\u00e4llet.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r bilagan.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL till den redigarade bildfilen.","type":"string","format":"uri","required":true},"modifiers":{"description":"Matris med bildredigeringar.","type":"array","minItems":1,"items":{"description":"Bildredigering.","type":"object","required":["type","args"],"oneOf":[{"title":"V\u00e4nd","properties":{"type":{"description":"Typ av spegling.","type":"string","enum":["flip"]},"args":{"description":"Argument f\u00f6r spegling.","type":"object","required":["flip"],"properties":{"flip":{"description":"Speglingsriktning.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Om du vill spegla horisontellt.","type":"boolean"},"vertical":{"description":"Om du vill spegla vertikalt.","type":"boolean"}}}}}}},{"title":"Rotering","properties":{"type":{"description":"Typ av rotering.","type":"string","enum":["rotate"]},"args":{"description":"Argument f\u00f6r rotering.","type":"object","required":["angle"],"properties":{"angle":{"description":"Vinkel f\u00f6r medurs rotation i grader.","type":"number"}}}}},{"title":"Besk\u00e4r","properties":{"type":{"description":"Typ av besk\u00e4rning.","type":"string","enum":["crop"]},"args":{"description":"Argument f\u00f6r besk\u00e4rning.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Horisontell position fr\u00e5n v\u00e4nster d\u00e4r besk\u00e4rning ska starta i procent av bildens bredd.","type":"number"},"top":{"description":"Vertikalt position fr\u00e5n toppen d\u00e4r besk\u00e4rningen ska starta i procent av bildens h\u00f6jd.","type":"number"},"width":{"description":"Besk\u00e4rningens bredd i procent av bildens bredd.","type":"number"},"height":{"description":"Besk\u00e4rningens h\u00f6jd i procent av bildens h\u00f6jd.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Hur mycket bilden ska roteras medurs i grader. F\u00d6R\u00c5LDRAT: Anv\u00e4nd `modifiers` i st\u00e4llet.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"I procent av bilden. X-positionen d\u00e4r besk\u00e4rningen ska starta. F\u00d6R\u00c5LDRAT: anv\u00e4nd `modifiers` i st\u00e4llet.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"I procent av bilden. Y-positionen d\u00e4r besk\u00e4rningen ska starta. F\u00d6R\u00c5LDRAT: anv\u00e4nd `modifiers` i st\u00e4llet.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"I procent av bilden. Till vilken bredd bilden ska besk\u00e4ras. F\u00d6R\u00c5LDRAT: anv\u00e4nd `modifiers` i st\u00e4llet.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"I procent av bilden. Till vilken h\u00f6jd bilden ska besk\u00e4ras. F\u00d6R\u00c5LDRAT: anv\u00e4nd `modifiers` i st\u00e4llet.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Bilagans bildtext.","type":"object","properties":{"raw":{"description":"Bildtext f\u00f6r bilagan som den ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-bildtext f\u00f6r bilagan, omvandlad f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Bilagans beskrivning.","type":"object","properties":{"raw":{"description":"Beskrivning av bilagan som den ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-beskrivning av bilagan, omvandlad f\u00f6r visning.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"ID f\u00f6r bilagans associerade inl\u00e4gg.","type":"integer","required":false},"alt_text":{"description":"Alternativ text att visa n\u00e4r bilagan inte visas.","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som publicerats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Begr\u00e4nsa svaret till inl\u00e4gg som publicerats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hur s\u00f6kbegrepp ska tolkas.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samlingen efter objektattribut.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array av kolumnnamn som ska s\u00f6kas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg med en eller flera specifika sluggar.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4r tilldelade en eller flera statusar.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false},"tax_relation":{"description":"Begr\u00e4nsa resultatet baserat p\u00e5 relationer mellan flera taxonomier.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Begr\u00e4nsa resultatet till objekt som tilldelats en viss term i taxonomin menus.","type":["object","array"],"oneOf":[{"title":"Lista \u00f6ver term-ID:n","description":"Matcha termer med uppr\u00e4knade ID:n.","type":"array","items":{"type":"integer"}},{"title":"S\u00f6kning i taxonomi \u00f6ver term-ID","description":"Genomf\u00f6r en avancerad terms\u00f6kning.","type":"object","properties":{"terms":{"description":"Term-ID:n.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Om inl\u00e4gg m\u00e5ste ha tilldelats alla eller n\u00e5gon av de angivna termerna.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Begr\u00e4nsa resultatet till alla objekt utom de som tilldelats en viss term i taxonomin menus.","type":["object","array"],"oneOf":[{"title":"Lista \u00f6ver term-ID:n","description":"Matcha termer med uppr\u00e4knade ID:n.","type":"array","items":{"type":"integer"}},{"title":"S\u00f6kning i taxonomi \u00f6ver term-ID","description":"Genomf\u00f6r en avancerad terms\u00f6kning.","type":"object","properties":{"terms":{"description":"Term-ID:n.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg med ett visst v\u00e4rde f\u00f6r menu_order.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Objektets rubrik.","type":["string","object"],"properties":{"raw":{"description":"Rubrik f\u00f6r objektet, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r objektet, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Objektsfamiljen som ursprungligen representeras, s\u00e5som \u201dpost_type\u201d eller \u201dtaxonomy\u201d.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"En namngiven status f\u00f6r objektet.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"parent":{"default":0,"description":"ID f\u00f6r objektets \u00f6verordnade objekt.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texten f\u00f6r title-attributet f\u00f6r l\u00e4nkelementet i detta menyobjekt.","type":"string","required":false},"classes":{"description":"Klassnamnen f\u00f6r l\u00e4nkelementet i detta menyobjekt.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Beskrivningen av detta menyval.","type":"string","required":false},"menu_order":{"default":1,"description":"DB-ID f\u00f6r nav_menu_item som \u00e4r detta objekts \u00f6verordnade objekt, om n\u00e5got finns. I annat fall 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Typen av ursprungligt objekt som representeras, s\u00e5som \u201dcategory\u201d, \u201dpost\u201d eller \u201dattachment\u201d.","type":"string","required":false},"object_id":{"default":0,"description":"Databas-ID f\u00f6r det ursprungliga objektet som detta menyval representerar, till exempel ID f\u00f6r inl\u00e4gg eller term_id f\u00f6r kategorier.","type":"integer","minimum":0,"required":false},"target":{"description":"Target-attributet f\u00f6r l\u00e4nkelementet i detta menyobjekt.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL:en som detta menyval pekar mot.","type":"string","format":"uri","required":false},"xfn":{"description":"XFN-relationen som uttrycks i detta menyobjekts l\u00e4nk.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Termer tilldelade till objektet i taxonomi nav_menu.","type":"integer","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"title":{"description":"Objektets rubrik.","type":["string","object"],"properties":{"raw":{"description":"Rubrik f\u00f6r objektet, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r objektet, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Objektsfamiljen som ursprungligen representeras, s\u00e5som \u201dpost_type\u201d eller \u201dtaxonomy\u201d.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"En namngiven status f\u00f6r objektet.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"parent":{"description":"ID f\u00f6r objektets \u00f6verordnade objekt.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texten f\u00f6r title-attributet f\u00f6r l\u00e4nkelementet i detta menyobjekt.","type":"string","required":false},"classes":{"description":"Klassnamnen f\u00f6r l\u00e4nkelementet i detta menyobjekt.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Beskrivningen av detta menyval.","type":"string","required":false},"menu_order":{"description":"DB-ID f\u00f6r nav_menu_item som \u00e4r detta objekts \u00f6verordnade objekt, om n\u00e5got finns. I annat fall 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Typen av ursprungligt objekt som representeras, s\u00e5som \u201dcategory\u201d, \u201dpost\u201d eller \u201dattachment\u201d.","type":"string","required":false},"object_id":{"description":"Databas-ID f\u00f6r det ursprungliga objektet som detta menyval representerar, till exempel ID f\u00f6r inl\u00e4gg eller term_id f\u00f6r kategorier.","type":"integer","minimum":0,"required":false},"target":{"description":"Target-attributet f\u00f6r l\u00e4nkelementet i detta menyobjekt.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL:en som detta menyval pekar mot.","type":"string","format":"uri","required":false},"xfn":{"description":"XFN-relationen som uttrycks i detta menyobjekts l\u00e4nk.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Termer tilldelade till objektet i taxonomi nav_menu.","type":"integer","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Om papperskorgen ska hoppas \u00f6ver och borttagning ske direkt i st\u00e4llet.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID f\u00f6r objektets \u00f6verordnade objekt.","type":"integer","minimum":0,"required":false},"title":{"description":"Objektets rubrik.","type":["string","object"],"properties":{"raw":{"description":"Rubrik f\u00f6r objektet, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-rubrik f\u00f6r objektet, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Objektsfamiljen som ursprungligen representeras, s\u00e5som \u201dpost_type\u201d eller \u201dtaxonomy\u201d.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"En namngiven status f\u00f6r objektet.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"attr_title":{"description":"Texten f\u00f6r title-attributet f\u00f6r l\u00e4nkelementet i detta menyobjekt.","type":"string","required":false},"classes":{"description":"Klassnamnen f\u00f6r l\u00e4nkelementet i detta menyobjekt.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Beskrivningen av detta menyval.","type":"string","required":false},"menu_order":{"description":"DB-ID f\u00f6r nav_menu_item som \u00e4r detta objekts \u00f6verordnade objekt, om n\u00e5got finns. I annat fall 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Typen av ursprungligt objekt som representeras, s\u00e5som \u201dcategory\u201d, \u201dpost\u201d eller \u201dattachment\u201d.","type":"string","required":false},"object_id":{"description":"Databas-ID f\u00f6r det ursprungliga objektet som detta menyval representerar, till exempel ID f\u00f6r inl\u00e4gg eller term_id f\u00f6r kategorier.","type":"integer","minimum":0,"required":false},"target":{"description":"Target-attributet f\u00f6r l\u00e4nkelementet i detta menyobjekt.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL:en som detta menyval pekar mot.","type":"string","format":"uri","required":false},"xfn":{"description":"XFN-relationen som uttrycks i detta menyobjekts l\u00e4nk.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Termer tilldelade till objektet i taxonomi nav_menu.","type":"integer","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Autosparade versionens ID.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som publicerats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Begr\u00e4nsa svaret till inl\u00e4gg som publicerats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hur s\u00f6kbegrepp ska tolkas.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter inl\u00e4ggsattribut.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array av kolumnnamn som ska s\u00f6kas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg med en eller flera specifika sluggar.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4r tilldelade en eller flera statusar.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false},"tax_relation":{"description":"Begr\u00e4nsa resultatet baserat p\u00e5 relationer mellan flera taxonomier.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Begr\u00e4nsa resultatet till objekt som tilldelats en viss term i taxonomin wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista \u00f6ver term-ID:n","description":"Matcha termer med uppr\u00e4knade ID:n.","type":"array","items":{"type":"integer"}},{"title":"S\u00f6kning i taxonomi \u00f6ver term-ID","description":"Genomf\u00f6r en avancerad terms\u00f6kning.","type":"object","properties":{"terms":{"description":"Term-ID:n.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Om inl\u00e4gg m\u00e5ste ha tilldelats alla eller n\u00e5gon av de angivna termerna.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Begr\u00e4nsa resultatet till alla objekt utom de som tilldelats en viss term i taxonomin wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista \u00f6ver term-ID:n","description":"Matcha termer med uppr\u00e4knade ID:n.","type":"array","items":{"type":"integer"}},{"title":"S\u00f6kning i taxonomi \u00f6ver term-ID","description":"Genomf\u00f6r en avancerad terms\u00f6kning.","type":"object","properties":{"terms":{"description":"Term-ID:n.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["view","edit"]},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Utdraget f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Utdrag f\u00f6r inl\u00e4gget, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-utdrag f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Om utdraget \u00e4r l\u00f6senordsskyddat.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false},"wp_pattern_category":{"description":"Termer tilldelade till inl\u00e4gget i taxonomi wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u00c5sidos\u00e4tt standardl\u00e4ngden f\u00f6r utdrag.","type":"integer","required":false},"password":{"description":"L\u00f6senordet f\u00f6r inl\u00e4gget om det \u00e4r l\u00f6senordsskyddat.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["view","edit"]},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Utdraget f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Utdrag f\u00f6r inl\u00e4gget, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-utdrag f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Om utdraget \u00e4r l\u00f6senordsskyddat.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false},"wp_pattern_category":{"description":"Termer tilldelade till inl\u00e4gget i taxonomi wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Om papperskorgen ska hoppas \u00f6ver och borttagning ske direkt i st\u00e4llet.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samlingen efter objektattribut.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true eftersom versioner inte kan hanteras via papperskorgen.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["view","edit"]},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Utdraget f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Utdrag f\u00f6r inl\u00e4gget, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-utdrag f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Om utdraget \u00e4r l\u00f6senordsskyddat.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false},"wp_pattern_category":{"description":"Termer tilldelade till inl\u00e4gget i taxonomi wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Autosparade versionens ID.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r en mall","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samlingen efter objektattribut.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r en mall","type":"string","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID f\u00f6r en mall","type":"string","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true eftersom versioner inte kan hanteras via papperskorgen.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID f\u00f6r en mall","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"ID f\u00f6r en mall","type":"string","required":false},"slug":{"description":"Unik slug som identifierar mallen.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Temaidentifierare f\u00f6r mallen.","type":"string","required":false},"type":{"description":"Typ av mall.","type":"string","required":false},"content":{"description":"Inneh\u00e5ll f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens inneh\u00e5ll, s\u00e5 som det finns i databasen.","type":"string","context":["view","edit"]},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av mallen.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Rubrik f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens rubrik som den ser ut i databasen.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-rubrik f\u00f6r mallen, omvandlad f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beskrivning av mall.","type":"string","required":false},"status":{"description":"Status f\u00f6r mall.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av mallen.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r en mall","type":"string","required":false},"id":{"description":"Autosparade versionens ID.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Begr\u00e4nsa till angivet inl\u00e4ggs-ID.","type":"integer","required":false},"area":{"description":"Begr\u00e4nsa till specificerat malldelomr\u00e5de.","type":"string","required":false},"post_type":{"description":"Inl\u00e4ggstyp att h\u00e4mta mallen f\u00f6r.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Unik slug som identifierar mallen.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Temaidentifierare f\u00f6r mallen.","type":"string","required":false},"type":{"description":"Typ av mall.","type":"string","required":false},"content":{"default":"","description":"Inneh\u00e5ll f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens inneh\u00e5ll, s\u00e5 som det finns i databasen.","type":"string","context":["view","edit"]},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av mallen.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Rubrik f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens rubrik som den ser ut i databasen.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-rubrik f\u00f6r mallen, omvandlad f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beskrivning av mall.","type":"string","required":false},"status":{"default":"publish","description":"Status f\u00f6r mall.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av mallen.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Sluggen till den malldel f\u00f6r vilken reserv ska h\u00e4mtas","type":"string","required":true},"is_custom":{"description":"Indikerar om en mall \u00e4r anpassad eller del av mallhierarkin","type":"boolean","required":false},"template_prefix":{"description":"Mallprefixet f\u00f6r den skapade mallen. Detta anv\u00e4nds f\u00f6r att extrahera huvudmalltypen, i `taxonomy-books` extraheras exempelvis `taxonomy`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID f\u00f6r en mall","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID f\u00f6r en mall","type":"string","required":false},"slug":{"description":"Unik slug som identifierar mallen.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Temaidentifierare f\u00f6r mallen.","type":"string","required":false},"type":{"description":"Typ av mall.","type":"string","required":false},"content":{"description":"Inneh\u00e5ll f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens inneh\u00e5ll, s\u00e5 som det finns i databasen.","type":"string","context":["view","edit"]},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av mallen.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Rubrik f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens rubrik som den ser ut i databasen.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-rubrik f\u00f6r mallen, omvandlad f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beskrivning av mall.","type":"string","required":false},"status":{"description":"Status f\u00f6r mall.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av mallen.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"ID f\u00f6r en mall","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Om papperskorgen ska hoppas \u00f6ver och borttagning ske direkt i st\u00e4llet.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r en mall","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samlingen efter objektattribut.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r en mall","type":"string","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID f\u00f6r en mall","type":"string","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true eftersom versioner inte kan hanteras via papperskorgen.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID f\u00f6r en mall","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"ID f\u00f6r en mall","type":"string","required":false},"slug":{"description":"Unik slug som identifierar mallen.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Temaidentifierare f\u00f6r mallen.","type":"string","required":false},"type":{"description":"Typ av mall.","type":"string","required":false},"content":{"description":"Inneh\u00e5ll f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens inneh\u00e5ll, s\u00e5 som det finns i databasen.","type":"string","context":["view","edit"]},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av mallen.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Rubrik f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens rubrik som den ser ut i databasen.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-rubrik f\u00f6r mallen, omvandlad f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beskrivning av mall.","type":"string","required":false},"status":{"description":"Status f\u00f6r mall.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av mallen.","type":"integer","required":false},"area":{"description":"Var malldelen \u00e4r avsedd att anv\u00e4ndas (sidhuvud, sidfot osv.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r en mall","type":"string","required":false},"id":{"description":"Autosparade versionens ID.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Begr\u00e4nsa till angivet inl\u00e4ggs-ID.","type":"integer","required":false},"area":{"description":"Begr\u00e4nsa till specificerat malldelomr\u00e5de.","type":"string","required":false},"post_type":{"description":"Inl\u00e4ggstyp att h\u00e4mta mallen f\u00f6r.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Unik slug som identifierar mallen.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Temaidentifierare f\u00f6r mallen.","type":"string","required":false},"type":{"description":"Typ av mall.","type":"string","required":false},"content":{"default":"","description":"Inneh\u00e5ll f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens inneh\u00e5ll, s\u00e5 som det finns i databasen.","type":"string","context":["view","edit"]},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av mallen.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Rubrik f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens rubrik som den ser ut i databasen.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-rubrik f\u00f6r mallen, omvandlad f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beskrivning av mall.","type":"string","required":false},"status":{"default":"publish","description":"Status f\u00f6r mall.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av mallen.","type":"integer","required":false},"area":{"description":"Var malldelen \u00e4r avsedd att anv\u00e4ndas (sidhuvud, sidfot osv.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Sluggen till den malldel f\u00f6r vilken reserv ska h\u00e4mtas","type":"string","required":true},"is_custom":{"description":"Indikerar om en mall \u00e4r anpassad eller del av mallhierarkin","type":"boolean","required":false},"template_prefix":{"description":"Mallprefixet f\u00f6r den skapade mallen. Detta anv\u00e4nds f\u00f6r att extrahera huvudmalltypen, i `taxonomy-books` extraheras exempelvis `taxonomy`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID f\u00f6r en mall","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID f\u00f6r en mall","type":"string","required":false},"slug":{"description":"Unik slug som identifierar mallen.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Temaidentifierare f\u00f6r mallen.","type":"string","required":false},"type":{"description":"Typ av mall.","type":"string","required":false},"content":{"description":"Inneh\u00e5ll f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens inneh\u00e5ll, s\u00e5 som det finns i databasen.","type":"string","context":["view","edit"]},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av mallen.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Rubrik f\u00f6r mall.","type":["object","string"],"properties":{"raw":{"description":"Mallens rubrik som den ser ut i databasen.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-rubrik f\u00f6r mallen, omvandlad f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beskrivning av mall.","type":"string","required":false},"status":{"description":"Status f\u00f6r mall.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"ID f\u00f6r f\u00f6rfattaren av mallen.","type":"integer","required":false},"area":{"description":"Var malldelen \u00e4r avsedd att anv\u00e4ndas (sidhuvud, sidfot osv.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"ID f\u00f6r en mall","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Om papperskorgen ska hoppas \u00f6ver och borttagning ske direkt i st\u00e4llet.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r \u00f6verordnat objekt till den globala stilversionen.","type":"integer","required":false},"id":{"description":"Unikt ID f\u00f6r \u201dglobala stilar\u201d-versionen.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Temats ID-str\u00e4ng","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Temats ID-str\u00e4ng","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID f\u00f6r global stilkonfiguration.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Globala stilar.","type":["object"],"required":false},"settings":{"description":"Globala inst\u00e4llningar.","type":["object"],"required":false},"title":{"description":"Rubrik p\u00e5 den globala stilvarianten.","type":["object","string"],"properties":{"raw":{"description":"Rubrik p\u00e5 den globala stilvarianten, som den \u00e4r angiven i databasen.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som publicerats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Begr\u00e4nsa svaret till inl\u00e4gg som publicerats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4ndrats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hur s\u00f6kbegrepp ska tolkas.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter inl\u00e4ggsattribut.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array av kolumnnamn som ska s\u00f6kas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg med en eller flera specifika sluggar.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Begr\u00e4nsa resultatet till inl\u00e4gg som \u00e4r tilldelade en eller flera statusar.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-inneh\u00e5ll f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"L\u00f6senordet f\u00f6r inl\u00e4gget om det \u00e4r l\u00f6senordsskyddat.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-inneh\u00e5ll f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Om papperskorgen ska hoppas \u00f6ver och borttagning ske direkt i st\u00e4llet.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samlingen efter objektattribut.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID f\u00f6r versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Unik identifierare f\u00f6r versionen.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true eftersom versioner inte kan hanteras via papperskorgen.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"date":{"description":"Det datum d\u00e5 inl\u00e4gget publicerades i webbplatsens tidszon.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Inl\u00e4ggets publiceringsdatum i GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4gget, som \u00e4r unik inom dess typ.","type":"string","required":false},"status":{"description":"En namngiven status f\u00f6r inl\u00e4gget.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ett l\u00f6senord f\u00f6r att skydda \u00e5tkomst till inneh\u00e5llet och utdraget.","type":"string","required":false},"title":{"description":"Rubriken f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Rubrik f\u00f6r inl\u00e4gget s\u00e5 som det ser ut i databasen.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-rubrik f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r inl\u00e4gget.","type":"object","properties":{"raw":{"description":"Inl\u00e4ggets inneh\u00e5ll, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-inneh\u00e5ll f\u00f6r inl\u00e4gget, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version av inneh\u00e5llsblockformat som anv\u00e4nds av inl\u00e4gget.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Om inneh\u00e5llet \u00e4r skyddat med ett l\u00f6senord.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Tema-filen som anv\u00e4nds f\u00f6r att visa inl\u00e4gget.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID f\u00f6r den autosparade versionens \u00f6verordnade objekt.","type":"integer","required":false},"id":{"description":"Autosparade versionens ID.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hur s\u00f6kbegrepp ska tolkas.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter inl\u00e4ggsattribut.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Begr\u00e4nsa resultatet till inl\u00e4gg med en eller flera specifika sluggar.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Version av theme.json-schemat som anv\u00e4nds f\u00f6r typografiinst\u00e4llningarna.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Deklaration av \u201dfont-family\u201d i \u201dtheme.json\u201d-format, kodad som en str\u00e4ng.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"theme_json_version":{"description":"Version av theme.json-schemat som anv\u00e4nds f\u00f6r typografiinst\u00e4llningarna.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Deklaration av \u201dfont-family\u201d i \u201dtheme.json\u201d-format, kodad som en str\u00e4ng.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r inl\u00e4gget.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Om papperskorgen ska hoppas \u00f6ver och borttagning ske direkt i st\u00e4llet.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"ID:t f\u00f6r den \u00f6verordnade typsnittsfamiljen f\u00f6r typsnittet.","type":"integer","required":true},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hur s\u00f6kbegrepp ska tolkas.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter inl\u00e4ggsattribut.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"ID:t f\u00f6r den \u00f6verordnade typsnittsfamiljen f\u00f6r typsnittet.","type":"integer","required":true},"theme_json_version":{"description":"Version av theme.json-schemat som anv\u00e4nds f\u00f6r typografiinst\u00e4llningarna.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"Deklaration av \u201dfont-face\u201d i \u201dtheme.json\u201d-format, kodad som en str\u00e4ng.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"ID:t f\u00f6r den \u00f6verordnade typsnittsfamiljen f\u00f6r typsnittet.","type":"integer","required":true},"id":{"description":"Unik ID-str\u00e4ng f\u00f6r typsnittet.","type":"integer","required":true},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"ID:t f\u00f6r den \u00f6verordnade typsnittsfamiljen f\u00f6r typsnittet.","type":"integer","required":true},"id":{"description":"Unik ID-str\u00e4ng f\u00f6r typsnittet.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Om papperskorgen ska hoppas \u00f6ver och borttagning ske direkt i st\u00e4llet.","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r inl\u00e4ggstypen.","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r statusen.","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Begr\u00e4nsa resultaten till taxonomier som \u00e4r f\u00f6rknippade med en viss inl\u00e4ggstyp.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r taxonomin.","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter termattribut.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Om termer som inte \u00e4r kopplade till n\u00e5got inl\u00e4gg ska d\u00f6ljas eller ej.","type":"boolean","default":false,"required":false},"parent":{"description":"Begr\u00e4nsa resultatet till termer som h\u00f6r till ett visst \u00f6verordnat objekt.","type":"integer","required":false},"post":{"description":"Begr\u00e4nsa resultatet till termer som h\u00f6r till ett specifikt inl\u00e4gg.","type":"integer","default":null,"required":false},"slug":{"description":"Begr\u00e4nsa resultatet till termer med en eller flera specifika \u201dsluggar\u201d.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-beskrivning av termen.","type":"string","required":false},"name":{"description":"Termens HTML-rubrik.","type":"string","required":true},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r termen, som \u00e4r unik inom dess typ.","type":"string","required":false},"parent":{"description":"Den \u00f6verordnade termens ID.","type":"integer","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"description":{"description":"HTML-beskrivning av termen.","type":"string","required":false},"name":{"description":"Termens HTML-rubrik.","type":"string","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r termen, som \u00e4r unik inom dess typ.","type":"string","required":false},"parent":{"description":"Den \u00f6verordnade termens ID.","type":"integer","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true eftersom termer inte kan hanteras via papperskorgen.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter termattribut.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Om termer som inte \u00e4r kopplade till n\u00e5got inl\u00e4gg ska d\u00f6ljas eller ej.","type":"boolean","default":false,"required":false},"post":{"description":"Begr\u00e4nsa resultatet till termer som h\u00f6r till ett specifikt inl\u00e4gg.","type":"integer","default":null,"required":false},"slug":{"description":"Begr\u00e4nsa resultatet till termer med en eller flera specifika \u201dsluggar\u201d.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-beskrivning av termen.","type":"string","required":false},"name":{"description":"Termens HTML-rubrik.","type":"string","required":true},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r termen, som \u00e4r unik inom dess typ.","type":"string","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"description":{"description":"HTML-beskrivning av termen.","type":"string","required":false},"name":{"description":"Termens HTML-rubrik.","type":"string","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r termen, som \u00e4r unik inom dess typ.","type":"string","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true eftersom termer inte kan hanteras via papperskorgen.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter termattribut.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Om termer som inte \u00e4r kopplade till n\u00e5got inl\u00e4gg ska d\u00f6ljas eller ej.","type":"boolean","default":false,"required":false},"post":{"description":"Begr\u00e4nsa resultatet till termer som h\u00f6r till ett specifikt inl\u00e4gg.","type":"integer","default":null,"required":false},"slug":{"description":"Begr\u00e4nsa resultatet till termer med en eller flera specifika \u201dsluggar\u201d.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-beskrivning av termen.","type":"string","required":false},"name":{"description":"Termens HTML-rubrik.","type":"string","required":true},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r termen, som \u00e4r unik inom dess typ.","type":"string","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":[],"required":false},"locations":{"description":"Platserna tilldelade till menyn.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Om sidor i toppniv\u00e5 automatiskt ska l\u00e4ggas till i denna meny.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"description":{"description":"HTML-beskrivning av termen.","type":"string","required":false},"name":{"description":"Termens HTML-rubrik.","type":"string","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r termen, som \u00e4r unik inom dess typ.","type":"string","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":[],"required":false},"locations":{"description":"Platserna tilldelade till menyn.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Om sidor i toppniv\u00e5 automatiskt ska l\u00e4ggas till i denna meny.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true eftersom termer inte kan hanteras via papperskorgen.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter termattribut.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Om termer som inte \u00e4r kopplade till n\u00e5got inl\u00e4gg ska d\u00f6ljas eller ej.","type":"boolean","default":false,"required":false},"post":{"description":"Begr\u00e4nsa resultatet till termer som h\u00f6r till ett specifikt inl\u00e4gg.","type":"integer","default":null,"required":false},"slug":{"description":"Begr\u00e4nsa resultatet till termer med en eller flera specifika \u201dsluggar\u201d.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-beskrivning av termen.","type":"string","required":false},"name":{"description":"Termens HTML-rubrik.","type":"string","required":true},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r termen, som \u00e4r unik inom dess typ.","type":"string","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"description":{"description":"HTML-beskrivning av termen.","type":"string","required":false},"name":{"description":"Termens HTML-rubrik.","type":"string","required":false},"slug":{"description":"En alfanumerisk ID-str\u00e4ng f\u00f6r termen, som \u00e4r unik inom dess typ.","type":"string","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r termen.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true eftersom termer inte kan hanteras via papperskorgen.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"default":"asc","description":"Sortera efter attributet i stigande eller fallande ordning.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sortera samling efter anv\u00e4ndarattribut.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Begr\u00e4nsa resultatet till anv\u00e4ndare med viss eller vissa permal\u00e4nkar.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Begr\u00e4nsa resultatet till anv\u00e4ndare som matchar minst en av de angivna rollerna. Kommaseparerad lista eller individuell roll accepteras.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Begr\u00e4nsa resultatet till anv\u00e4ndare som matchar minst en av de angivna beh\u00f6righeterna. Kommaseparerad lista eller individuell beh\u00f6righet accepteras.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Begr\u00e4nsa resultatet till anv\u00e4ndare som betraktas som f\u00f6rfattare.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Begr\u00e4nsa resultatet till anv\u00e4ndare som har publicerade inl\u00e4gg.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face"}},"required":false},"search_columns":{"default":[],"description":"Array av kolumnnamn som ska s\u00f6kas.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Inloggningsnamn f\u00f6r anv\u00e4ndaren.","type":"string","required":true},"name":{"description":"Visningsnamn f\u00f6r anv\u00e4ndaren.","type":"string","required":false},"first_name":{"description":"Anv\u00e4ndarens f\u00f6rnamn.","type":"string","required":false},"last_name":{"description":"Anv\u00e4ndarens efternamn.","type":"string","required":false},"email":{"description":"E-postadress f\u00f6r anv\u00e4ndaren.","type":"string","format":"email","required":true},"url":{"description":"Anv\u00e4ndarens URL.","type":"string","format":"uri","required":false},"description":{"description":"Beskrivning av anv\u00e4ndaren.","type":"string","required":false},"locale":{"description":"Spr\u00e5kkod (locale) f\u00f6r anv\u00e4ndaren.","type":"string","enum":["","en_US","sv_SE"],"required":false},"nickname":{"description":"Anv\u00e4ndarens smeknamn.","type":"string","required":false},"slug":{"description":"Alfanumerisk ID-str\u00e4ng f\u00f6r anv\u00e4ndaren.","type":"string","required":false},"roles":{"description":"Roller tilldelade anv\u00e4ndaren.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"L\u00f6senord f\u00f6r anv\u00e4ndaren (ing\u00e5r aldrig).","type":"string","required":true},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Datumet och tidpunkten d\u00e5 alternativen uppdaterades.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r anv\u00e4ndaren.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r anv\u00e4ndaren.","type":"integer","required":false},"username":{"description":"Inloggningsnamn f\u00f6r anv\u00e4ndaren.","type":"string","required":false},"name":{"description":"Visningsnamn f\u00f6r anv\u00e4ndaren.","type":"string","required":false},"first_name":{"description":"Anv\u00e4ndarens f\u00f6rnamn.","type":"string","required":false},"last_name":{"description":"Anv\u00e4ndarens efternamn.","type":"string","required":false},"email":{"description":"E-postadress f\u00f6r anv\u00e4ndaren.","type":"string","format":"email","required":false},"url":{"description":"Anv\u00e4ndarens URL.","type":"string","format":"uri","required":false},"description":{"description":"Beskrivning av anv\u00e4ndaren.","type":"string","required":false},"locale":{"description":"Spr\u00e5kkod (locale) f\u00f6r anv\u00e4ndaren.","type":"string","enum":["","en_US","sv_SE"],"required":false},"nickname":{"description":"Anv\u00e4ndarens smeknamn.","type":"string","required":false},"slug":{"description":"Alfanumerisk ID-str\u00e4ng f\u00f6r anv\u00e4ndaren.","type":"string","required":false},"roles":{"description":"Roller tilldelade anv\u00e4ndaren.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"L\u00f6senord f\u00f6r anv\u00e4ndaren (ing\u00e5r aldrig).","type":"string","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Datumet och tidpunkten d\u00e5 alternativen uppdaterades.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unik ID-str\u00e4ng f\u00f6r anv\u00e4ndaren.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true, eftersom anv\u00e4ndare inte kan hanteras via papperskorgen.","required":false},"reassign":{"type":"integer","description":"F\u00f6r \u00f6ver den borttagna anv\u00e4ndarens inl\u00e4gg och l\u00e4nkar till detta anv\u00e4ndar-ID.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Inloggningsnamn f\u00f6r anv\u00e4ndaren.","type":"string","required":false},"name":{"description":"Visningsnamn f\u00f6r anv\u00e4ndaren.","type":"string","required":false},"first_name":{"description":"Anv\u00e4ndarens f\u00f6rnamn.","type":"string","required":false},"last_name":{"description":"Anv\u00e4ndarens efternamn.","type":"string","required":false},"email":{"description":"E-postadress f\u00f6r anv\u00e4ndaren.","type":"string","format":"email","required":false},"url":{"description":"Anv\u00e4ndarens URL.","type":"string","format":"uri","required":false},"description":{"description":"Beskrivning av anv\u00e4ndaren.","type":"string","required":false},"locale":{"description":"Spr\u00e5kkod (locale) f\u00f6r anv\u00e4ndaren.","type":"string","enum":["","en_US","sv_SE"],"required":false},"nickname":{"description":"Anv\u00e4ndarens smeknamn.","type":"string","required":false},"slug":{"description":"Alfanumerisk ID-str\u00e4ng f\u00f6r anv\u00e4ndaren.","type":"string","required":false},"roles":{"description":"Roller tilldelade anv\u00e4ndaren.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"L\u00f6senord f\u00f6r anv\u00e4ndaren (ing\u00e5r aldrig).","type":"string","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Datumet och tidpunkten d\u00e5 alternativen uppdaterades.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"M\u00e5ste ha v\u00e4rdet true, eftersom anv\u00e4ndare inte kan hanteras via papperskorgen.","required":false},"reassign":{"type":"integer","description":"F\u00f6r \u00f6ver den borttagna anv\u00e4ndarens inl\u00e4gg och l\u00e4nkar till detta anv\u00e4ndar-ID.","required":true}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"En UUID-str\u00e4ng fr\u00e5n applikationen som unikt identifierar den. Rekommendationen \u00e4r att anv\u00e4nda UUID v5 med namnrymd fr\u00e5n URL eller DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Applikationsl\u00f6senordets namn.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"En UUID-str\u00e4ng fr\u00e5n applikationen som unikt identifierar den. Rekommendationen \u00e4r att anv\u00e4nda UUID v5 med namnrymd fr\u00e5n URL eller DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Applikationsl\u00f6senordets namn.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"after":{"description":"Begr\u00e4nsa svaret till kommentarer som publicerats efter ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Begr\u00e4nsa resultatet till kommentarer som \u00e4r tilldelade vissa anv\u00e4ndar-ID:n. Kr\u00e4ver auktorisering.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Se till att resultatet utesluter kommentarer som \u00e4r tilldelade vissa anv\u00e4ndar-ID:n. Kr\u00e4ver auktorisering.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Begr\u00e4nsa resultatet till en specifik f\u00f6rfattares e-postadress. Kr\u00e4ver auktorisering.","format":"email","type":"string","required":false},"before":{"description":"Begr\u00e4nsa svaret till kommentarer som publicerats f\u00f6re ett visst datum enligt formatet ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter kommentarattribut.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Begr\u00e4nsa resultatet till kommentarer med specifika \u00f6verordnade ID:n.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Se till att resultatet inte inneh\u00e5ller \u00f6verordnade objekt med specifika ID:n.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Begr\u00e4nsa resultatet till kommentarer som tilldelats specifika inl\u00e4ggs-ID:n.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Begr\u00e4nsa resultatet till kommentarer som tilldelats en viss status. Kr\u00e4ver auktorisering.","type":"string","required":false},"type":{"default":"comment","description":"Begr\u00e4nsa resultatet till kommentarer som tilldelats en viss typ. Kr\u00e4ver auktorisering.","type":"string","required":false},"password":{"description":"L\u00f6senordet f\u00f6r inl\u00e4gget om det \u00e4r l\u00f6senordsskyddat.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"Anv\u00e4ndarobjektets ID om f\u00f6rfattaren var en anv\u00e4ndare.","type":"integer","required":false},"author_email":{"description":"E-postadress f\u00f6r kommentarens f\u00f6rfattare.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-adress f\u00f6r kommentarens f\u00f6rfattare.","type":"string","format":"ip","required":false},"author_name":{"description":"Visningsnamn f\u00f6r kommentarens f\u00f6rfattare.","type":"string","required":false},"author_url":{"description":"URL f\u00f6r kommentarens f\u00f6rfattare.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Anv\u00e4ndaragent-str\u00e4ng f\u00f6r kommentarens f\u00f6rfattare.","type":"string","required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r kommentaren.","type":"object","properties":{"raw":{"description":"Inneh\u00e5llet f\u00f6r kommentaren, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-inneh\u00e5ll f\u00f6r kommentaren, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Det datum d\u00e5 kommentaren publicerades i webbplatsens tidszon.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Datumet som kommentaren publicerades, i GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"ID f\u00f6r kommentarens \u00f6verordnade objekt.","type":"integer","required":false},"post":{"default":0,"description":"ID f\u00f6r associerat inl\u00e4ggsobjekt.","type":"integer","required":false},"status":{"description":"Kommentarens status.","type":"string","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Anteckningens avklarningsstatus","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unik identifierare f\u00f6r kommentaren.","type":"integer","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"L\u00f6senordet f\u00f6r kommentarens \u00f6verordnade inl\u00e4gg (om inl\u00e4gget \u00e4r l\u00f6senordsskyddat).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unik identifierare f\u00f6r kommentaren.","type":"integer","required":false},"author":{"description":"Anv\u00e4ndarobjektets ID om f\u00f6rfattaren var en anv\u00e4ndare.","type":"integer","required":false},"author_email":{"description":"E-postadress f\u00f6r kommentarens f\u00f6rfattare.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-adress f\u00f6r kommentarens f\u00f6rfattare.","type":"string","format":"ip","required":false},"author_name":{"description":"Visningsnamn f\u00f6r kommentarens f\u00f6rfattare.","type":"string","required":false},"author_url":{"description":"URL f\u00f6r kommentarens f\u00f6rfattare.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Anv\u00e4ndaragent-str\u00e4ng f\u00f6r kommentarens f\u00f6rfattare.","type":"string","required":false},"content":{"description":"Inneh\u00e5llet f\u00f6r kommentaren.","type":"object","properties":{"raw":{"description":"Inneh\u00e5llet f\u00f6r kommentaren, s\u00e5 som det ser ut i databasen.","type":"string","context":["edit"]},"rendered":{"description":"HTML-inneh\u00e5ll f\u00f6r kommentaren, omvandlat f\u00f6r visning.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Det datum d\u00e5 kommentaren publicerades i webbplatsens tidszon.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Datumet som kommentaren publicerades, i GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"ID f\u00f6r kommentarens \u00f6verordnade objekt.","type":"integer","required":false},"post":{"description":"ID f\u00f6r associerat inl\u00e4ggsobjekt.","type":"integer","required":false},"status":{"description":"Kommentarens status.","type":"string","required":false},"meta":{"description":"Metadataf\u00e4lt.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Anteckningens avklarningsstatus","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unik identifierare f\u00f6r kommentaren.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Om papperskorgen ska hoppas \u00f6ver och borttagning ske direkt i st\u00e4llet.","required":false},"password":{"description":"L\u00f6senordet f\u00f6r kommentarens \u00f6verordnade inl\u00e4gg (om inl\u00e4gget \u00e4r l\u00f6senordsskyddat).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"type":{"default":"post","description":"Begr\u00e4nsa resultat till objekt av en viss objektstyp.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Begr\u00e4nsa resultatet till objekt av en eller flera undertyper f\u00f6r objekt.","type":"array","items":{"enum":["post","page","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"Se till att resultatet inte inneh\u00e5ller specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Begr\u00e4nsa resultatet till specifika ID:n.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Unikt registrerat namn f\u00f6r blocket.","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attribut f\u00f6r blocket.","type":"object","default":[],"required":false},"post_id":{"description":"ID f\u00f6r inl\u00e4ggets kontext.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namnrymd f\u00f6r block.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namnrymd f\u00f6r block.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Blocknamn.","type":"string","required":false},"namespace":{"description":"Namnrymd f\u00f6r block.","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"Rubrik","description":"Webbplatsrubrik.","type":"string","required":false},"description":{"title":"Slogan","description":"Webbplatsslogan.","type":"string","required":false},"timezone":{"title":"","description":"En ort i din tidszon.","type":"string","required":false},"date_format":{"title":"","description":"Ett datumformat f\u00f6r alla str\u00e4ngar med datum.","type":"string","required":false},"time_format":{"title":"","description":"Ett tidsformat f\u00f6r alla str\u00e4ngar med klockslag.","type":"string","required":false},"start_of_week":{"title":"","description":"Numret p\u00e5 dagen i veckan som veckan ska b\u00f6rja p\u00e5.","type":"integer","required":false},"language":{"title":"","description":"Kod f\u00f6r spr\u00e5kversion (locale) i WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"Konvertera emotikon-symboler som :-) och :-P till riktiga emojier vid visning.","type":"boolean","required":false},"default_category":{"title":"","description":"Standardkategori f\u00f6r inl\u00e4gg.","type":"integer","required":false},"default_post_format":{"title":"","description":"Standardformat f\u00f6r inl\u00e4gg.","type":"string","required":false},"posts_per_page":{"title":"Maximalt antal inl\u00e4gg per sida","description":"Bloggsidor visar h\u00f6gst.","type":"integer","required":false},"show_on_front":{"title":"Visa p\u00e5 startsida","description":"Vad som visas p\u00e5 startsidan","type":"string","required":false},"page_on_front":{"title":"Sida p\u00e5 startsida","description":"ID f\u00f6r den sida som ska visas p\u00e5 startsidan","type":"integer","required":false},"page_for_posts":{"title":"","description":"ID f\u00f6r sidan som ska visa de senaste inl\u00e4ggen","type":"integer","required":false},"default_ping_status":{"title":"","description":"Till\u00e5t notiser om nya l\u00e4nkar fr\u00e5n andra bloggar (pingback och trackback) f\u00f6r nya artiklar.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Till\u00e5t kommentarer p\u00e5 nya inl\u00e4gg","description":"Till\u00e5t att andra skickar in kommentarer p\u00e5 nya inl\u00e4gg.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logga","description":"Webbplatslogga.","type":"integer","required":false},"site_icon":{"title":"Ikon","description":"Webbplatsikon.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Begr\u00e4nsa resultatet till teman som har tilldelats en eller flera statusar.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Temats stilmall, som unikt identifierar temat.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"status":{"description":"Begr\u00e4nsar resultaten till till\u00e4gg med den givna statusen.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Slug i WordPress till\u00e4ggskatalog.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Till\u00e4ggets aktiveringsstatus.","type":"string","enum":["inactive","active","network-active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Till\u00e4ggets aktiveringsstatus.","type":"string","enum":["inactive","active","network-active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID f\u00f6r en registrerad sidopanel","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Widgetar ordnade inuti varandra.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Widgettyp-ID.","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Widgettyp-ID.","type":"string","required":true},"instance":{"description":"Nuvarande instansinst\u00e4llningar f\u00f6r widgeten.","type":"object","required":false},"form_data":{"description":"Serialiserade formul\u00e4rdata fr\u00e5n widet f\u00f6r inkodning i instansinst\u00e4llningar.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Widgettyp-ID.","type":"string","required":true},"instance":{"description":"Nuvarande instansinst\u00e4llningar f\u00f6r widgeten.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Sidopanelen, vars widgetar ska returneras.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikt ID f\u00f6r widgeten.","type":"string","required":false},"id_base":{"description":"Typ av widget. Motsvarar ID i \u00e4ndpunkt f\u00f6r widgettyper.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Sidopanelen som widgeten tillh\u00f6r.","type":"string","required":true},"instance":{"description":"Instansinst\u00e4llningar f\u00f6r widgeten, om detta st\u00f6ds.","type":"object","properties":{"encoded":{"description":"Base64-kodad representation av instansinst\u00e4llningarna.","type":"string","context":["edit"]},"hash":{"description":"Kryptografisk hash f\u00f6r instansinst\u00e4llningarna.","type":"string","context":["edit"]},"raw":{"description":"Okodade instansinst\u00e4llningar, om detta st\u00f6ds.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodade formul\u00e4rdata fr\u00e5n widgeten adminformul\u00e4r. Anv\u00e4nds f\u00f6r att uppdatera en widget som saknar st\u00f6d f\u00f6r instansen. Endast skrivbar.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikt ID f\u00f6r widgeten.","type":"string","required":false},"id_base":{"description":"Typ av widget. Motsvarar ID i \u00e4ndpunkt f\u00f6r widgettyper.","type":"string","required":false},"sidebar":{"description":"Sidopanelen som widgeten tillh\u00f6r.","type":"string","required":false},"instance":{"description":"Instansinst\u00e4llningar f\u00f6r widgeten, om detta st\u00f6ds.","type":"object","properties":{"encoded":{"description":"Base64-kodad representation av instansinst\u00e4llningarna.","type":"string","context":["edit"]},"hash":{"description":"Kryptografisk hash f\u00f6r instansinst\u00e4llningarna.","type":"string","context":["edit"]},"raw":{"description":"Okodade instansinst\u00e4llningar, om detta st\u00f6ds.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodade formul\u00e4rdata fr\u00e5n widgeten adminformul\u00e4r. Anv\u00e4nds f\u00f6r att uppdatera en widget som saknar st\u00f6d f\u00f6r instansen. Endast skrivbar.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Om du vill tvinga borttagning av widgeten, eller flytta den till den inaktiva sidopanelen.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Begr\u00e4nsa resultatet till block som matchar s\u00f6ktermen.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","minLength":1,"required":false},"category":{"description":"Begr\u00e4nsa resultaten till de som matchar ett kategori-ID.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Begr\u00e4nsa resultaten till de som matchar ett nyckelords-ID.","type":"integer","minimum":1,"required":false},"slug":{"description":"Begr\u00e4nsa resultaten till s\u00e5dana som matchar ett m\u00f6nster (slug).","type":"array","required":false},"offset":{"description":"Hoppa fram\u00e5t ett visst antal objekt i resultatet.","type":"integer","required":false},"order":{"description":"Sortera efter attributet i stigande eller fallande ordning.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortera samling efter inl\u00e4ggsattribut.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL:en som ska bearbetas.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"En alfanumerisk identifierare f\u00f6r menyplatsen.","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Unikt ID-nummer f\u00f6r f\u00f6rm\u00e5gekategorin.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Unikt ID-nummer f\u00f6r f\u00f6rm\u00e5gan.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Indataparametrar f\u00f6r k\u00f6rning av f\u00f6rm\u00e5gan.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Begr\u00e4nsa s\u00f6kresultaten till f\u00f6rm\u00e5gor som ing\u00e5r i viss f\u00f6rm\u00e5gekategori.","type":"string","required":false},"namespace":{"description":"Begr\u00e4nsa s\u00f6kresultaten till f\u00f6rm\u00e5gor som ing\u00e5r i en viss namnrymd.","type":"string","required":false},"meta":{"description":"Begr\u00e4nsa resultaten till f\u00f6rm\u00e5gor som uppfyller alla angivna metaf\u00e4lt.","type":"object","properties":{"annotations":{"description":"Begr\u00e4nsa resultaten till f\u00f6rm\u00e5gor som st\u00e4mmer \u00f6verens med de angivna beteendeanm\u00e4rkningarna.","type":"object","properties":{"readonly":{"description":"Om f\u00f6rm\u00e5gan inte p\u00e5verkar sin omgivning.","type":["boolean","null"]},"destructive":{"description":"Om f\u00f6rm\u00e5gan kan utf\u00f6ra skadliga f\u00f6r\u00e4ndringar i sin omgivning.","type":["boolean","null"]},"idempotent":{"description":"Om upprepade anrop med samma argument inte ger n\u00e5gon ytterligare effekt.","type":["boolean","null"]}},"additionalProperties":true}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Unikt ID-nummer f\u00f6r f\u00f6rm\u00e5gan.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false},"collection":{"description":"Begr\u00e4nsa resultaten till ikoner som tillh\u00f6r den givna sluggen f\u00f6r samlingen.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<collection>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"collection":{"description":"Begr\u00e4nsa resultaten till ikoner som tillh\u00f6r den givna sluggen f\u00f6r samlingen.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false}}}]},"\/wp\/v2\/icons\/(?P<name>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?\/[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Ikonnamn.","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/icon-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuell sida i samlingen.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximalt antal objekt som ska finnas med i resultatet.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Begr\u00e4nsa resultaten till de som matchar en str\u00e4ng.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/icon-collections"}]}},"\/wp\/v2\/icon-collections\/(?P<slug>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug f\u00f6r ikonsamlingen.","type":"string","required":false},"context":{"description":"Omf\u00e5ng (scope) f\u00f6r vilket beg\u00e4ran g\u00f6rs. Best\u00e4mmer vilka f\u00e4lt som ska finnas med i svaret.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/view-config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"description":"Entitetstyp.","type":"string","required":true},"name":{"description":"Entitetsnamn.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/dev.clubcorvette.se\/oldies\/wp-json\/wp\/v2\/view-config"}]}}},"site_logo":0,"site_icon":0,"site_icon_url":"","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}]}}
